Brief Description: More Work on Engine Installation
Modified the cylinder head cooling fins on Cylinder #1 to allow clearance for the cowl. It was real hard making this modification to such a beautiful engine.....but it had to be done. The fuel tank vent connection was finally completed a small section of flexible tubing was connected between the tank and the vent tubing. Stainless steel clamps were installed . The stater solenioid was installed. The cable from the starter was made shorter and a cable from the battery to the solenoid was made from #2 cable with the correct ends soldered on.
