Michael's Sonex Project
Sonex Tri-Gear
SNX-L05
Installing Brake Parts
After allowing the primer to dry overnight, the TriGear Brake cable guide, SNX-L05-10, was installed inside the spar box. The holes in the rear of the spar box were drilled for the grommets and brake cables, which were installed.
Brake Cable Guide Installed
Cable Guide Routing
Sonex Tri-Gear Home
1602
Canopy / Windscreen
Cowl
146
Finish Work
Flight and Tuning
106
Fuselage, Aft
59
106
Fuselage, Forward
123
252
Panel
Propeller
360
Workshop
