The Top Aft Wing skin was riveted in place working from the main spar toward the rear spar. The leading edge skin was then cleco'd in place and then riveted using flush rivets. The wing was flipped and the bottom side of the leading edge skin was cleco'd in place. It was discovered that a dent had been created in the leading edge on the top side. I am investigating ways to fix the dent.
