The Fiberglass wingtip cuts that were previously made were cleaned up with files. Part of the bottom flange had to be removed with a Dremel Cutoff tool for proper fitting. The Tip was then placed, drilled and cleco'd to the bottom skin. Once the wing is flipped the top wing skin will be drilled and cleco'd. The Flap hinge was placed and drilled according to the plans. Ed Bodette helped me flip the wing over for addition work.
