Michael's Sonex Project
Sonex Tri-Gear
SNX-W07
Drilling Right Wing
The holes in the right forward spar were drilled to #30 size. The forward skin was started to be drilled with a #31 drill. A #31 drill is being used because the holes will be dimpled and this process causes the holes to enlarge.
Sonex Tri-Gear Home
1602
Canopy / Windscreen
Cowl
146
Finish Work
Flight and Tuning
106
Fuselage, Aft
59
106
Fuselage, Forward
123
252
Panel
Propeller
360
Workshop
