Brief Description: Leveling Right Wing for Top Skin
The Right wing assembly was leveled and clamped in place. This was done by first ripping a 2x6 pine board with an angle of about 11 degrees. This was placed under the rear spar and then clamps were placed between the rear spar and the table edge. A level was placed between the rear and main spars and blocks were added under the main spar to keep the whole assembly level. Small clips were added to the blocks that clamped the main spar to the table. Once everything was leveled the top skin was placed and clamped in place.
