Michael's Sonex Project
Sonex Tri-Gear
SNX-W14
Main Wing Ribs
The Cleco'd ribs were drilled up to final size and re-cleco'd with the larger fasteners. The alignment holes were drill out to size with a step drill bit then deburred and Snap-bushings were installed.
Ribs Installed
Rib Alignment
Wingtip Lights Snap Bushings
Sonex Tri-Gear Home
1602
Canopy / Windscreen
Cowl
146
Finish Work
Flight and Tuning
106
Fuselage, Aft
59
106
Fuselage, Forward
123
252
Panel
Propeller
360
Workshop
