The two Bell Crank Spacers, SNX-W21-05 and SNX-W21-08, were made out of aluminum. This was okayed by Sonex-LTD as a replacement to phenolic. The Aileron Bellcrank plate was deburred and drilled. The Upper and Lower Left Bellcrank angles, SNX-W21-06 and SNX-W21-07, were cut and filed to shape. The holes in the two angles were match drilled along with the left spacer. The bellcrank bushings were cut to size and deburred.
