Michael's Sonex Project
Sonex Tri-Gear
SNX-W15
Forward Ribs
Rib Gussets were attached to the remaining four forward ribs (SNX-W15-03, SNX-W15-04) The parts were located per plans, drilled, deburred and then riveted in place. Zinc Oxide primer was put on the rib where the gussets attach.
Sonex Tri-Gear Home
1602
Canopy / Windscreen
Cowl
146
Finish Work
Flight and Tuning
106
Fuselage, Aft
59
106
Fuselage, Forward
123
252
Panel
Propeller
360
Workshop
