Michael's Sonex Project
Sonex Tri-Gear
SNX-W15
Rib Attach Gussets
The eight SNX-W15-06 and eight SNX-W15-7 Gussets were drilled as indicated on the plans and then cut to shape using bandsaw and snips. The gussets still need to be cleaned up on the edges.
Gussets cut to shape and drilled
Sonex Tri-Gear Home
1602
Canopy / Windscreen
Cowl
146
Finish Work
Flight and Tuning
106
Fuselage, Aft
59
106
Fuselage, Forward
123
252
Panel
Propeller
360
Workshop
