Michael's Sonex Project
Sonex Tri-Gear
SNX-W12
Outboard Rear Spar Channels
From the SNX-Z01-02 Channel Stock the Right Hand, SNX-W12-03R, and Left Hand, SNX-W12-03L, Outboard Rear Spar Channels were constructed. The part was cut to shape, holes drilled, large hole cut out, and then deburred and cleaned up with scotchbrite.
Fabricating the Parts
Both Outboard Rear Spar Channels
Right Hand Outboard Rear Spar Channel
Sonex Tri-Gear Home
1602
Canopy / Windscreen
Cowl
146
Finish Work
Flight and Tuning
106
Fuselage, Aft
59
106
Fuselage, Forward
123
252
Panel
Propeller
360
Workshop
