Michael's Sonex Project
Sonex Tri-Gear
SNX-W08
Aligned and drilled Spars Together
The two spars were aligned using the alignment holes and then clamped together. The five holes were then drilled and then reamed to 1/4" size.
Spars match drilled and Clamped together
Sonex Tri-Gear Home
1602
Canopy / Windscreen
Cowl
146
Finish Work
Flight and Tuning
106
Fuselage, Aft
59
106
Fuselage, Forward
123
252
Panel
Propeller
360
Workshop
