Brief Description: Working on Fiberglass Tail Tips
Finished installing all Rivnuts and attached the fiberglass tail tip using Stainless Steel 6-32 screws. I quickly found a problem with the installation. The clearance with the elevator is too tight and doesn't allow easy movement. The Tail tip support rib location was moved to give more clearance.
