Michael's Sonex Project
Sonex Tri-Gear
SNX-T03
Horizontal Main Spar Fitting
Finished SNX-T03-02 Main Spar Fitting after a lot of work with a vixen file. Then made two SNX-T03-03 Spar attach Angles. The parts were bent using a bench vise and a dead blow hammer to the required 10 degrees.
Sonex Tri-Gear Home
1602
Canopy / Windscreen
Cowl
146
Finish Work
Flight and Tuning
106
Fuselage, Aft
59
106
Fuselage, Forward
123
252
Panel
Propeller
360
Workshop
