Michael's Sonex Project
Sonex Tri-Gear
SNX-T08
Attaching Tail Wing Skin
Finally got the first side aligned, drilled and cleco'd. This ended up being a very time consuming process. Once the first side was done I moved on to the second side. I was able to drill and cleco the top and rear areas of the skin.
First Side Drilled and Cleco'd
Drilling and Aligning Second Side
Sonex Tri-Gear Home
1602
Canopy / Windscreen
Cowl
146
Finish Work
Flight and Tuning
106
Fuselage, Aft
59
106
Fuselage, Forward
123
252
Panel
Propeller
360
Workshop
