Michael's Sonex Project
Sonex Tri-Gear
SNX-T01
Adjusting Rudder Movement
The Left and Right Rudder Stops were adjusted to get the required rudder deflection. Also some minor adjustments were needed to the elevator horn due to an interference problem. A few minutes with a file and everything moved freely.
Measuring Rudder Deflection
Final Left Rudder Stop
Final Right Rudder Stop
Sonex Tri-Gear Home
1602
Canopy / Windscreen
Cowl
146
Finish Work
Flight and Tuning
106
Fuselage, Aft
59
106
Fuselage, Forward
123
252
Panel
Propeller
360
Workshop
