Fixed the two discrepencies found yesterday. Drilled a larger hole for the EIS warning light and filed about 1/16" from the support angle to allow the AP & COM to fit correctly. Temporary screws were installed in the instruments and tightened down. The custom Graphics display mount was test fitted but more work needs to be done. I also discovered that the small stop holes for the toggle switches were installed on the top whereas they should have been on the bottom....ooppss!!! Two choices, use lock washers instead or drill new holes on the bottom. I'll think about it.
