The Nose wheel Strut was installed, hopefully for the last time. The Travel stop bolt, bushing and nut was installed at the top of the strut. The Travel stop plate was located according to plans and drilled. The Travel Stop Plate, SNX-L02-04, and Push Rod Boot Plate, SNX-L02-06, were painted with Zinc Oxide primer. The Travel Stop Plate was then installed using the required Bolt/Nut combination. The whole fuselage was taken off the saw horses and placed on its landing gear. 70lbs of weight was added to the engine mount to help balance the fuselage on the ground.
