Brief Description: Drilling Welded Main Gear Mounts
Still drilling holes on the Tri-Gear main gear mounts. The left gear mount was drilled up through the lower fuselage skin with the SNX-L04-03 spacer in place. The holes in both mounts (R & L) into the Spar Box assembly were drilled. Next the 7 holes in the support angle were drilled and cleco'd on each of the gear mounts. Last, the hole for the rear support piece were drilled.
