Michael's Sonex Project
Date: 5-7-2006
Number of Hours: 4.00
Manual Reference: SNX-F16
Brief Description: Cleaning up SNX-F16 Parts and building Assemblies
The Lower Forward Cross Tie,SNX-F16-10, was Filed to final size. Two (right and left) Vertical Angles, SNX-F16-06R/L, were filed to final size. The Support Angle, SNX-F16-04, was filed to final size. The Aft Tunnel Web Assembly, SNX-F16-03 was clamped up and drilled. The parts were dis-assembled and deburred. The Aft Tunnel Angle, SNX-F16-05, was dimpled. The Vertical Angles, SNX-F16-06R/L, and Support Angle, SNX-F16-04, was countersunk. The part was re-assembled to check fit.
Front Side of Web Assembliy, SNX-F16-03
Back Side of Web Assembliy, SNX-F16-03
