Today was a parts day. The Forward Tunnel Zee, SNX-F16-02, part was drawn on the provided Z05-01 Angle stock. The holes were located and drilled. The part was not cut to final size. Next the Aft Tunnel Angle, SNX-F16-05, part was drawn on the provided Z05-02. The holes were located and drilled. The part was not cut to final size. Two pre-cut Shear Plates, SNX-F16-07, were unpacked and deburred. Two Side Clips, SNX-F16-08, were made from Z01-03 Angel stock. The part was cut to size and the holes were drilled and deburred.
