Brief Description: Completed Left Forward Fuselage Skin Assembly
The left forward fuselage skin assembly was reassembled with clecos. The parts were then riveted as indicated on the plans. Notice in the photographs that the Aft wing Attach angles and gussets were not riveted according to the plans. Finally the specified bolts were installed, torqued down the the correct setting.
