Brief Description: Started the Forward Fuselage Side Skin Asseblies
Started work on the Forward Fuselage Side Skin Assembly, SNX-F12. I pulled on of the two skins and noticed something wasn't quite right. Upon further investigation, I noticed that the two skins were note identical! Since these were provided in the kit, I assumed they were both the same. After comparing the measurements to the plans, SNX-F13-01, I discovered one of the skins was mis-cut by Sonex. I have sent them an email requesting their assistance. With the one remaining good skin, I started the assembly of the left hand side. Assembly is proceeding according to the assembly order indicated on the plans.
