I made the fuel filler template same as on the Left wing. Fitted the tanks and applied the right amount of cork to the underside, Added the spacers to the ribs to secure the tanks. Drilled and installed both fuel senders into the tanks. I am ordering the fuel lines and parts required to run the fuel lines. I have decided to go to aluminum lines but will need to sort out what parts are required.
As well I will go back to the Left wing and istall the same aluminum tubing that I will be ordering for Right wing.
