Working on a final clean up of the wiring. I may revamp some of this as I am not happy with some of the wire runs. I will see after I get them strapped down and secure. If it is cluttered then I will make some changes to the terminations. It should be easy as I have labeled each and every wire with a printed label and clear heat shrink. Most of the wiring is complete and everything is working great. A couple of sensors to hook up still which include the outdoor air temp, fuel pressure, and fuel flow sensors. Fuel system is next.
