Brief Description: General planning on wire routing
Spent sometime planning where and how to run some of the extensive wires that attach to the various components. I will most like ly need to build a track for the wire which I will use to further strengthen the panel and avionics. As well i mounted the Voltage Regulator and read up on the Rotax install Manual as to where and what I need to tie in for wires.
Just a photo of the wiring that has to be dealt with.
