Mark & Michelle STOL CH701
Date:  1-4-2007
Number of Hours:  2.50
Manual Reference:  7R
Brief Description:  Completed Rudder
Completed the rudder today. No real issues with the assembly. I may have 4 rivets to drill out as the plans tell you in later steps only to cleco these 4 rivets but in the previous step it had said to rivet. Not a big problem but I will wait till I have to attach the skin there to see which will need to be removed. I have marked it so I won't forget. On to the HS.
Completed the riveting
Checked the alignment and it was perfect. Hope the rest is a easy as this.
Hard to see but the trailing edge is perfect as well.
