Mark & Michelle STOL CH701
Date:  2-10-2008
Number of Hours:  3.00
Brief Description:  Engine Hoses
Completed installing the radiator hoses and oil lines. I had to replace the two fittings on the water pump as they needed to be moved as per the plans so that they will clear the ring mount. They were very difficult to move without destroying the elbows. I ordered two new ones and reinstlled with Blue lock-tite.
Reattached the cooling hoses. I needed to re route the bottom oil pick up hose through the ring mount to make room for the exhaust.
