Brief Description: Drill remaining holes in HS-814-1, HS-810-1, and H
Remove the skin and drill the remaining holes in HS-814-1, HS-8101 and HS-00003. Remove HS-810-1, HS-814-1 and HS-00003.
When I removed these parts, I noticed HS-0003 was one hole off when it was mounted. This caused holes to be drilled in the wrong location in the spar doubler (HS-0003) and forward spart (HS-702). I acquired replacement parts and will need to redo all work related to HS-702 and HS-0003.
