Brief Description: Match drill skin to HS-00005 rib. Re-clamp HS-000
Beginning at the rear spar and working forward, match drill the holes in the HS-801PP skins to the HS-00005 rib.
Be sure that the front flange of HS-00005, HS-702, HS-810-1 and HS-814-1, HS-00003 and the aft flange of HS-00006 are pulled up tight. Re-clamp the upper and lower flanges of HS-00006 to HS-801PP.
