Brief Description: Match drill HS-00006 to HS-702 and HS-00003. Mark
Match drill #40 the holes in the aft flange of the HS-00006 rib to HS-702 and HS-00003.
Mark and drill #40 the two holes common to the HS-00003, HS-702, HS-810-1 or HS-814-1 on the forward side ofthe spar bars, keeping the holes in line with the holes in the aft flange of the HS-00006 rib. See section D-D.
