MICHAEL'S WEB SITE
Date: 1-7-2018
Number of Hours: 0.50
Manual Reference: 6.4.4 - 6.4.5
Brief Description: Cleco HS-702, HS-603PP, HS-706, HS-707, and HS-708
Select the left side HS-702, HS-603PP, HS-706, HS-707, and HS-708 and cleco them together.
Drill HS-706, HS-707, HS-708 rib to spar attach holes to #30 (except the HS-708 and HS-603PP holes).
Image 3 shows the some of the rib flanges need to be straightened a little better. I went through all ribs again at this point to ensure the flange was at 90 degrees to the web.
