Brief Description: Dimple and Countersink HS-702, HS-810-1, and HS-81
Using view A-A to identify the four holes, demple HS-702 and countersink HS-810-1 and HS-814-1. This was my first time to do this so it took a while to properly adjust everything. The dimple dyes need to be a little tighter than the width of HS-702 in order to get a properly formed dimple. I used an AN426AD4-6 rivet to help size the dimple. I then used the dimpled HS-702 to help size the countersink being made into HS-810-1 and HS-814-1.
