Brief Description: Profile HS-810-1 and HS-814-1 reinforcement angle.
Remove HS-810-1 and HS-814-1 from front spar assembly and mark the taper to the ends. Used a disc sander to profile the ends as shown in image 3. Once the profile was made, I filed the taper to remove most of the marks left by the disc sander and then finished off the taper with the 3M wheel.
