Brief Description: Identified parts for section 6.2, separate HS-0000
Located all parts needed for section 6.2. Separated two apar doublers HS-00003, draw rivet line according to plans. Note, there are no notes on the plans with regard to this step, I simply drew a line from the other holes out threw the end of HS-00003. I'm not sure if this is correct or not, but we will see if it makes since later on.
