Brief Description: HS-411APP, HS411BPP, and VA-146
Clamp HS-411APP and HS-411BPP around VA0146 and cleco to read spar assembly. Drill the 4 holes closest to the rear, then remoe the clamped bearing assembly and drill out the remaining two holes using a #30 drill bit.
The can of primer I purchased will not spray so step 6.1.9 will be completed after I acquire another can.
