Installed rear fuel tank baffle in right tank. Cleaned skins with acetone. Taped off tank areas pre builders manuel to keep clean. Mixed pro seal 75 grams and applied to both the skin, ribs,and rear tank baffle. Be sure to put a good amount of pro seal in corners of ribs.
