Made two trips, one for fuselage and one for the wings. Bolted wings to tripods and slid them on. It takes some time to get everything lined up for the wing pins to install, but once you do it works great. Take your time and get the adjustments right. Started engine for the firt time on the Panther. This is one smooth running engine. Adjusted idle stop on carb, was set to low. Static RPM 2790, Weight 742 lbs., 68.89 Empty CG.
