Brents Panther Project
Date:  5-22-2016
Number of Hours:  4.00
Brief Description:  FIRST ENGINE START
Started engine for the first time on Panther. We did a complete engine run break in at the Panther work shop in January. Ran engine for about an hour on test stand. Need to adjust idle, to low (400 rpm). Checked full static RPM 2790. Checked EGT at full power was able to get a EGT raise of 150 deg, not to lean.
Check mixture cutoff RPM's RPM went up about 150 before engine stopped. Mixture looks good on low end.
