Installed baffling and rubber baffle material. Everything fit good except corner for the oil cooler. Bracket was 1 5/8" wide which was to wide for the 9 row oil cooler. I had Dan make one 1 3/8" and it fit perfect. I used the corvair rear metal cooling baffle and made a cover for the old oil cooler hole. Then started installing the silcone rubber baffling. Slow going lots of curves.
