Installed rudder pedal and brake assembly. I left the power coating tight for the brake pedal so it wouldnt move on me while adjusting. Then took 2 paint stirring sticks (12") and attached from firewall frame to brake pedal attchachment bolts on each side at the same lenght.
Then had to get in the Panther in order to set brake pedal angle:) By leaving the power coating on the brake pedal part this kept them tight so they didnt move easy while adjusting.
Then I got out and marked brake pedal postion to rod prepare to drill for bolts.
