The next day I pulled string from the rear former to the firewall with a block were the instrument panel will be located. Straight as a arrow. So I started laying out the bolt holes on the side, bottom and tops. Drilled #14, reamed .18875 and clecoed everything together. Pulled sections back apart and started deburring.
