Drilled bottom outboard and inboard skins on. Before I stated on the boItom skins I drilled each corner of the rear spar and pulled dental floss across rear spar to be sure it was straight with 7/16 line drawn on rear spar using T brace under rear spar to adjust as needed,
Time to fit outboard nose skin, My skin has the prepunched skin and ribs so the bottom rivet line is 5/16 not 7/16 as the plans call for per Dan.
Both inboard skins were 1/8" to long compared to outboard skins, I trimmed both of these to be sure when fuel tanks are install wing skins will not interfere with rear tank baffle,
