Brief Description: Setting up paint booth - chopping up the shop
If I'm going to paint, I need a paint booth of some type. I have the room to do one of those drop down plastic things in the main hangar but this is better.
So, after much brainstorming, it became clear that partitioning off the end of my shop would work well. I needed a a wall with plastic, a door, some air inlets and exhaust fans.
(BTW, if the pre-hung door looks a little funny in the middle of this plastic sheet room, think again. This plane building project has taught me that you are going to spend 10X more time doing everything than you originally thought. I knew I'd be thru this door dozens of times a day - as I sit here updating this in October, it turned out to be true, squared. A plastic sheet door would have sucked (pun intended))
A video walk through the can be seen here: http://www.youtube.com/watch?v=Qkoc_327lnM
