Brief Description: QB inspection Mid Fuselage and bottom skins
QB inspection Mid Fuselage and bottom skins On 26-7 Fig 1, 20 nutplates are depicted. However on 26-8 a correction is made and only 18 are used. Apparently my skin had 2 unnecessary nutplates pre-drilled holes eliminated rather than 'ignored' as spec'd on plans. The nutplates had to be installed. (first constructive action on QB fuse)
on 26-7 a nutplate is erroneously depicted between these two pre-drilled holes
