Bill's RV-10 Builder Page
RV-10
Installed heat controls
Wanted to get this mounted independent of avionics panel because it has to be threaded from the knob thru any holes to the heat boxes.
I plan to rebuild the heat boxes and replace aluminum door flap with stainless and the aluminum hinges with steel hinge leftover from main gear struts
fabricated bracket and face plate
Mounted on tunnel...
Beneath Throttle quadrant
RV-10 Home
2016
ADS-B
Alexander Tech Cente
First Flight 8/25/20
Horizontal Tail
62
154
Maintenance & Post B
O2 Console
Painting A-Z
Panel
Tailcone
Undercarriage & Engi
Vertical Tail
Wheel pants
Workshop
