Bill's RV-10 Builder Page
Date:  11-3-2007
Number of Hours:  6.00
Brief Description:  Installed brake lines and master cylinder
Found best way to insert brass sleeves in nylon brake lines was to use pick to push and twist them in. Heated pick for last cm. A real knuckle buster getting whole brass elbow assembly together. by the 6th and last one, could probably do them easily.
My Darling inspecting work
using pick to insert brass sleeve
Brake lines and cylinders arell installed
