You can figure out how the console was mounted in the plane from the images. An aluminum plate with angle stock is riveted to the bottom of the console and hinges were used to attach it to the center tunnel. What you can't see is how the tank is mounted to the plate. I used one of Aerox's steel mounting straps to attach the tank to the plate. It has a thumbscrew to tighten the stee strap and that can be accessed thru one of the console top hatches.
You can see various cutouts mades to provide access to the tank as well as misc storage next to the pilot seat. Hatch covers were fabricated in various ways as needed.
For the iPad a RAM mount was installed that works just fine... and much better than the knee board I've been using.
