Bill's RV-10 Builder Page
Date:  3-9-2012
Number of Hours:  5.00
Brief Description:  Adding NavWorx ADS-B unit
Here is the NavWorx box and the wiring harness provided by FastStack.
The unit will be installed behind the baggage compartment using the Vans strobe power supply plate (my third one)
You can see the purpose built UAT antenna supplied by NavWorx. I'll be adding a used GA56 GPS antenna. It came recommended by everyone since there are a lot of used ones out there for about $50.
FastStack wiring harness and UAT Antenna
