Brief Description: More Sanding the engine cowling
At this point, I'm convinced that the original 3 coats of filling primer just needed to be sanded, a few chips and dings filled, then another coat or 2 of filler.
I got a bigger tip from my gun so I'm hoping I can shoot a smooter coat which should sand out easily.. A little fill here or there and then hold until time for the white primer and topcoat.
on the bottom half, I plan no fill except for a few rivet depressions
